Get-RDMSession : Connection not found.
Since upgrading to 2022.3.xx we have had an issue with our powershell consistently connecting.
IsConnected : False
IsOffline : False
Type : SQLServer
How can I get my powershell connect to connect to RDM? I have open/closed and done everything I can think of to get it to connect.
please advise.
All Comments (4)
If you were using an older RDM version in which the module was included in the RDM Installer file, then you now need to import it from PSGallery first.
You will find how to install and use the RDM PowerShell Core module on this article.
https://kb.devolutions.net/kb_rdmpowershellcore.html
Let me know if you have any questions about it.
Érica Poirier
This is my version. Binary 2021.2.0.14 RemoteDesktopManager
Upgrading to latest version of 2022.3.0 appears to have resolved the issue in limited testing. I know you moved it out of the install path but you could still upgrade the PSModule when you did an install of RDM.
Thank you for your feedback and glad the latest RDM PS Module has solved the issue.
At the moment we need to manually update the RDM PowerShell Module. I will send your comment to our engineering team.
Érica Poirier
