How to Disable right click menu ssh sessions RDM 2022.3.15
Implemented
in the new version of RDM you now get a context menu when you right click.
now it past sometimes and you get the menu, how to disable the menu so you only paste with a right click
All Comments (6)
it's a known bug and should be fixed in 2022.3.16.0
Min
It looks like this bug is back again in the newest version 2023.1.25.0 64-bit.
Unless it can be turned off somehow.
JK
Another user reported this issue coming back as well and we are currently working on a fix.
Actually I double checked, and the fix was made yesterday internally, so you can expect the fix in 2023.1.26.0.
Ok. Thank you for the quick feedback.
Hi, I have version 2023.1.29.0 64-bit
It is still there:
