When you are in a session and click on the Home menu on top and then choose Macros/Scripts you get a popup with all the scripts you have defined, in our case this is such a long list that we have to scroll to the bottom for a script we frequently use, the idea of a script is that it saves you time, by default the menu with scripts is expanded. My suggestion is to have it collapsed by default. And even preferably have it remember which section of macro's you had open/closed last time you used it. In our case we have grouped the scripts into folders.
Thank you for the suggestion. I have opened a ticket so we can improve this.
