Remote Desktop Manager 2022.3.8.0 64-bit (Beta) issues
Issue #1 (the installation):
I was using the RDM Free version 2022.2.26.0 when I saw the upgrade to RDM 2202.3.8.0 64-bit (Beta) was available. When I clicked on the automated built-in installer it to do the upgrade it did not upgrade to that version. So, I had to manually click on the link to RDM 2202.3.8.0 64-bit (Beta) and download it that way. Then when I installed it from that download, it installed a separate version of RDM 2202.3.8.0 64-bit (Beta) and did not upgrade my RDM Free version. So, now I have 2 versions of the product running on my pc. But in Windows Add/Remover Programs I do not see the older RDM Free version any longer, all I see is the new RDM 2202.3.8.0 64-bit (Beta) version although both are installed on my PC and both work fine.
Issue #2 (loss of functionality):
For me, one of the main differences is the older RDM Free version 2022.2.26.0 works with my current Devolutions Online Drive and Devolutions Password Hub Personal data sources but the new version 2022.3.8.0 Beta does not at this time. I could be wrong, but I did not see any mention of either of these products NOT working with the RDM 2202.3.8.0 64-bit (Beta) in the release notes.
These issues of mine are documented in a ticket with Zachary and a chat with Zachary and James [from Devolutions]. I just wanted to post my issues here just in case anyone else was experiencing them as well.
All Comments (1)
I've found the issue for DOD and Password Hub, This is now fixed and should be available in the next beta release later today. I will verify what could have happened for the update.
