Web login not connecting to RDM
From some days now, the web login plugin (on Chrome) does not work anymore.
It says 'Failed while sending request. Please verify if your RDM is open'.
Obviously, RDM is open and I can see listening on the default port, 19443 (as 'System' process). See attached.
What else can I verify to restore this functionality?
RDM is version 2022.2.26.0 64-bit, web login is 2022.2.7.1
forum image
forum image
Thanks
Stefano
All Comments (2)
Thank you for contacting the Devolutions Support Desk !
I believe this article should help you with your DWL issue: https://kb.devolutions.net/kb_dwl_http(s)_via_native_messaging.html
Best Regards
Great!
Now it work again, thank you for your help.
Stefano
