Hi, i am having trouble adding PHB as data source.
I write the name and username:
click ... and i have one host to choose from. It has a format companyname.devolutions.app
after a click it and test connection i get:
The host is not editable.
What to do?
Thanks in advance
Odd, for now, using the file attached, change the values to match your settings and import the data source configuration into RDM.
File > Data Sources > Import Data Source Configuration
Stéfane Lavergne
PHB.rdd
The team has informed me that the fix has already been applied internally. We are working on getting a new build released.
Please use the workaround until then.
Stéfane Lavergne
Thanks, i managed to edit the file You send and add data source.
Have a good day
