Double click on tab reconnect not working
I have setup DoubleClick on tab reconnect server in last beta version 2022.3.8.0 64-bit (Beta) it not working.
Standard, smart, legacy reconnect not working , full is working OK.
All Comments (5)
We've also been able to reproduce this issue on our end, so we'll open a ticket and keep you updated on the progress.
Jonathan Del Signore
Thank you for contacting the Devolutions Support Desk !
Would it be possible to send a screenshot of your File > Options > Types > Remote Desktop configuration ?
Thank you !
Best Regards,
Thank you !
Best Regards,
Thank you for this screenshot, we will add it to the ticket opened with our Engineering Department and be in touch as soon as we will have an update to provide.
James Lafleur
We've found the cause of this issue and deployed a fix internally. It will be included in version 2022.3.9.0.
