Devolutions web login(DWL), MFA code copy to clipboard after credentials paste
I’m looking for at way to get DWL to automatically copy the MFA code/OTP to clipboard, after I paste in the username and password.
Since the functionality to save the OTP key to the credentials entry is already there, hopefully it's possible :)
A program that I use privately that has this functionality is Bitwarden. It’s also a Chrome add-in, and it does this.
They describe is as follows(probably better than I ever could):
Premium Bitwarden accounts can use the Bitwarden Authenticator to generate timed one-time passcodes (OTP) for multi-factor authentication (MFA) for websites. When logging in, autofill will copy this six digit OTP code to the clipboard for easy pasting, so authenticating is fast and effortless!
Thank you for RDM, great tool!
With RDM and DWL, you can actually fill the OTP code directly on the website using the “One time password ID” attribute in tab “Login -> Html Control ID” tab from the edit Website form:
All you need to know is the field id/name where you want the OTP to be filled, which would the field where you paste the OTP code with the clipboard. To know the field id/name you can follow the “Method 2” from the help page below:
https://kb.devolutions.net/rdm_web_browser_web_authentication.html
That way, DWL will fill your username, password and OTP without even having to use the clipboard and pasting it yourself.
Olivier Désalliers
In my experience that functionality is only as good as the website is. Many sites i have not been able to make it work correctly, hence why i just want to do it manually by pasting it from the clipboard. :D
Yes, there are always edge cases because of some websites. We will open a ticket for your feature request. Thank you for your feedback.
Olivier Désalliers
We are also waiting for this feature as the autofill often does not work at all on specific websites.
We currently use Lastpass for the passwords and RDM for the connections. We are planning to migrate the passwords to RDM and this feature already exists in Lastpass.
