On Application Lock, Devolutions Web Login extension should lock as well.
I have my RDM set to lock itself if I minimize it, lock the computer, etc. The one thing I noticed is that DWL still works even if the application is locked.
Is it possible to have a setting so the DWL connection is disconnected until the application is unlocked?
All Comments (5)
Thank you for your feedback, we will open a ticket about this.
Olivier Désalliers
I've already done a chat session about this and the person told me to open a Feature Request, because this is by design.
Yes, the ticket we have opened is a feature request, the engineering team will analyze it and we will come back to you.
Olivier Désalliers
Just checking back in regard to my question. Thanks.
According to the information I have found on that matter, this feature should be available in the latest BETA of RDM Enterprise.
If you would like to test this version without affecting your current installation, I recommend creating a portable installation of RDM. To do so, you will need to do the following:
https://devolutions.net/remote-desktop-manager/home/thankyou/rdmbinbeta
4- Go to this folder once the .zip file has been extracted and run remotedesktopmanager64.exe
5- Use the local data source created by default for your tests
James Lafleur
