ssh with sftp option does not work as expected.
Hi there,
When i edit a file with Notepad using ssh-sftp and then save it, it is also saved to the server in an updated form.
If i do the same with VC (Visual Studio Code Editor), the modifications is not saved to the server.
This would be important because of json, c++ files etc.
thx
Stefan
PS: latest RDM Version, local.
I'm wondering if you could provide me a small recording of the behavior?
I will send you a link via private message to which you can upload your recording.
Let me know,
Samuel Dery
Hi Sam,
thanks for your help.
But after trying again, interestingly, it now works with VC.
What was the cause here, i can not tell you.
Best regards
Stefan Sabolowitsch
No problem, I'm glad to hear that it is now working for you!
Samuel Dery
