Is there a way to block "custom" credentials / is there a way to restrict the "view password" function
Is there a way to block entering "custom" credentials on sessions in an effort to force them to be put in dedicated credential objects?
Also, is there a way to limit access to "View Password" but not limit access to copy creds to the clipboard?
Eric Sakariasen
Connetic IT Support
All Comments (4)
What type of data source are you using? Is it Devolutions Server?
Jeff,
Oops sorry, Microsoft SQL on the latest client version.
Eric Sakariasen
Connetic IT Support
To allow Copy password, the View password is required (they could copy paste it anywhere anyway...)
There is no option to force the utilization of a credential instead of custom, but you can restrict the access to Edit entries once they're set.
As an administrator, you can also easily spot entries that have Custom credentials with the Entry Security Analyzer in RDM > Tools.
I hope this helps,
Alex Belisle
Alex,
Thanks for the update.
Eric Sakariasen
Connetic IT Support
