is there a way how to auto log off from a session with Display Mode External (RDC)?
Backlog
I am wondering if there is a way how to set up auto log off from a RDC session when I am using Display Mode: External?
I set Automatically log off when disconnecting to: Yes but it is not working with the External Display Mode.
Thanks.
All Comments (5)
My apologies for the delay, I have a few questions which you can hopefully answer.
  • Which version of RDM are you using?
  • Which type of data source are you using?
When launching the session in "Embedded" mode are you being logged off when disconnecting as expected?
Let me know,
Samuel Dery
currently I am using the version 2022.2.18.0 64-bit and the SQL Lite data source.
When I tried to open sessions in "Embedded" mode I received an error when I closed sessions:
Does this mean that auto log off should be working in the "External" mode too but I have a different problem when it is not working in the "Embedded" mode?
(I clicked the link "Learn more" but no solution helped me with that error).
Thank you for your reply,
I see, I will discuss your case with our engineering department to confirm what the expected behavior would be in this case.
I will keep you updated.
Samuel Dery
Thank you for your patience,
As mentioned I've discussed your case with our engineering department,
Unfortunately, I'm afraid that at this time this would be the expected behavior when launching the connection in "External" display mode, as from my understanding this would not be an option currently available in RDP.
That being said, I've opened a ticket for you regarding this to our engineering department and they will investigate if this could be possible.
I will keep you updated on any news I receive.
Samuel Dery
thank you very much for your help and information. I appreciate it.
Best Regards,
Milan
