Difference between SSH SHELL and Putty SSH
Implemented
Dear team,
we might have found a bug in the default SSH shell of Remote Desktop Manager. When performing specific own written updates, only the last line is being updated and other lines disappear. At the end, the screen is cleared.
I have attached a .gif file where you can see what happens. We do not have this problem when using the ssh connection via PUTTY.
Do you know if this is a known issue or something new?
System where we SSH to and more information:
  • Linux Debian 8 - Jessie
  • SSH SHELL - Embedded (tabbed)
  • Terminal settings - all default
Devolutions Remote Desktop Manager version 2022.2.16.0
Kind Regards,
Mitch
All Comments (8)
Are you using Remote Desktop Manager Enterprise or Free?
Best Regards,
Etienne Lord
Hi Etienne,
Enterprise
Could you enable the session recording for your SSH Session and recreate the behavior, this should create 2 files.
From there, send those files using the link I will send you via Private Messages.
Best Regards,
Etienne Lord
Thank you Etienne,
the recorded sessions has been send to you.
Kind Regards,
Mitch
Thank you for the files, I will investigate with the engineering department!
Best Regards,
Etienne Lord
We have made a fix that will be available in RDM 2022.2.19.0.
Hi Hubert,
thank you very much. Today we update to version 2022.2.20.0 and tested the SSH shell. It seems to be working fine now with the build in shell.
Kind Regards,
Mitch
Hello Mitch,
Thanks for the feedback, I'm glad that it now works for you!
