Webbrowser override on entry setting for personal preference
Add override options per user / profile based to use a different browser then what is set in the entry.
Either one setting to override all or an option per browser type override.
So I might be able to set Chrome to replace Edge or vise versa but leave Internet Explorer.
For many sites it does not matter which browser is used but people have different personal preferences or browsers setup to their liking with their own password manager.
All Comments (1)
You should already be able to override the browser choice with the User Specific Settings. You can access them by right clicking the entry > Edit > User specific settings.
You will then be able to edit the browser:
Does this work for you? Otherwise, what is missing from this solution to help in your scenario?
