Focus problem
Hello together
I currently have the latest version of RDM installed. Version 2022.1.27.0
Since this version something important is not working for us.
I don't know if this is a setting or not.
But if I am in a session and work on a server and need a password, I could simply right-click on an entry and copy the password in the old version.
Now RDM changes immediately to this entry.
After that you have to go back to the session .
All Comments (4)
There is an option that can toggle whether or not RDM focuses on an open session's tab when its corresponding entry in the Navigation pane is clicked.
You can find this option under File > Options > User Interface > Tree View, named Auto focus tab on item select. Turning this option off should solve your problem.
Let us know if that helps!
Gabriel Degrandpré
Hello Gariel
Unfortunately, that didn't help.
I still have the same problem
Thank you for your response. In that case, could you please follow the steps below to set up a portable instance of the latest version of RDM and let me know if this issue still persists on the new instance? This test will allow us to verify if the issue might be tied to your current configurations or to the version of RDM you use.
Here are the steps to create a portable instance of RDM :
1. Download the RDM zip folder from the link below :
2. Extract this zip in an empty folder of your choice
3. Launch RemoteDesktopManager64.exe from this folder
4. Register your license
5. Verify if the issue occurs on this instance of RDM as well
Gabriel Degrandpré
Hey Gabriel
You have now sent me version 2022.2.14.0.
But our server still has 2022.1.13.0. Do I have to update the server first with this version?
Regards Alex
