move OTP from custom to vault?
is there a way to use an OTP configuration specified as "custom" in a session entry to the vault to use it on more than one session or do I need to recreate it?
forum image
Hello Perler,
Thank you for contacting us regarding this,
I see, unfortunately, this is not possible. That being said, perhaps you could create a "One-Time Password (OTP)" entry in your "Navigation Pane" and use the "Linked (Vault)" option in the "Source" field of your entry "Properties".
This would allow you to link the same "OTP" in multiple entries.
Let me know if this helps,
Samuel Dery
sure, that's the idea. Did so, worked :)
Hello Perler,
Perfect, glad to hear this works for you!
Samuel Dery
