RDP sessions keep disconnecting
After update to 2022.1.15.0 I have an issue: RDP sessions are disconnected (and reconnected) after a second or two.
OS ver 12.4, updated today.
External rdp is working fine.
Here are the example logs:
[18:15:00:440] [1922:0a930000] [INFO][Devolutions.Rdp.Credentials] - parsing "A************", "" (Mstsc) => "Username: "A************" Domain: """
[18:15:00:448] [1922:0a930000] [DEBUG][com.freerdp.core] - freerdp_connect:freerdp_set_last_error_ex resetting error state
[18:15:00:449] [1922:0a930000] [DEBUG][com.freerdp.client.common.cmdline] - loading channelEx rdpdr
[18:15:00:450] [1922:0a930000] [DEBUG][com.freerdp.client.common.cmdline] - loading channelEx rdpsnd
[18:15:00:450] [1922:0a930000] [DEBUG][com.freerdp.client.common.cmdline] - loading channelEx RDMJump
[18:15:00:450] [1922:0a930000] [DEBUG][com.freerdp.client.common.cmdline] - loading channelEx RDMCmd
[18:15:00:450] [1922:0a930000] [DEBUG][com.freerdp.client.common.cmdline] - loading channelEx RDMLog
[18:15:00:451] [1922:0a930000] [DEBUG][com.freerdp.channels.cliprdr.client] - VirtualChannelEntryEx
[18:15:00:451] [1922:0a930000] [DEBUG][com.freerdp.client.common.cmdline] - loading channelEx cliprdr
[18:15:00:451] [1922:0a930000] [DEBUG][com.freerdp.channels.drdynvc.client] - VirtualChannelEntryEx
[18:15:00:451] [1922:0a930000] [DEBUG][com.freerdp.client.common.cmdline] - loading channelEx drdynvc
[18:15:00:452] [1922:0a930000] [ERROR][com.freerdp.channels.virtual.channel] - Unhandled event type 0
[18:15:00:453] [1922:0a930000] [ERROR][com.freerdp.channels.virtual.channel] - Unhandled event type 0
[18:15:00:708] [1922:0a930000] [DEBUG][com.freerdp.primitives] - primitives benchmark result:
[18:15:00:867] [1922:0a930000] [DEBUG][com.freerdp.primitives] - * generic= 18
[18:15:00:018] [1922:0a930000] [DEBUG][com.freerdp.primitives] - * optimized= 142
[18:15:00:018] [1922:0a930000] [DEBUG][com.freerdp.primitives] - primitives autodetect, using optimized
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Enabling security layer negotiation: TRUE
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Enabling restricted admin mode: FALSE
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Enabling RDP security: TRUE
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Enabling TLS security: TRUE
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Enabling NLA security: TRUE
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Enabling NLA extended security: FALSE
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_INITIAL --> CONNECTION_STATE_NEGO
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - state: NEGO_STATE_NLA
[18:15:00:019] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Attempting NLA security
[18:15:00:020] [1922:0a930000] [DEBUG][com.freerdp.core] - freerdp_tcp_is_hostname_resolvable:freerdp_set_last_error_ex resetting error state
[18:15:00:020] [1922:0a930000] [DEBUG][com.freerdp.core] - freerdp_tcp_default_connect:freerdp_set_last_error_ex resetting error state
[18:15:00:021] [1922:0a930000] [DEBUG][com.freerdp.core] - connecting to peer 10.0.0.250
[18:15:00:037] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - RequestedProtocols: 3
[18:15:00:143] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - RDP_NEG_RSP::flags = { [0x0f] EXTENDED_CLIENT_DATA_SUPPORTED|DYNVC_GFX_PROTOCOL_SUPPORTED|RDP_NEGRSP_RESERVED|RESTRICTED_ADMIN_MODE_SUPPORTED }
[18:15:00:143] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - selected_protocol: 2
[18:15:00:143] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - state: NEGO_STATE_FINAL
[18:15:00:143] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - Negotiated NLA security
[18:15:00:143] [1922:0a930000] [DEBUG][com.freerdp.core.nego] - nego_security_connect with PROTOCOL_HYBRID
[18:15:01:389] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - -- NLA_STATE_INITIAL --> NLA_STATE_INITIAL
[18:15:01:389] [1922:0a930000] [DEBUG][com.winpr.sspi] - InitSecurityInterfaceExA
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - nla_client_init 1078 : packageName=Negotiate ; cbMaxToken=12256
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - InitializeSecurityContext status SEC_I_CONTINUE_NEEDED [0x00090312]
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> sending...
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> protocol version 6
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> nego token
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> client nonce
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - [93 bytes]
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - -- NLA_STATE_INITIAL --> NLA_STATE_NEGO_TOKEN
[18:15:01:390] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_NEGO --> CONNECTION_STATE_NLA
[18:15:01:597] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - <<----- receiving...
[18:15:01:597] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - <<----- protocol version 5
[18:15:01:597] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - <<----- nego token
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - InitializeSecurityContext status SEC_E_OK [0x00000000]
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> sending...
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> protocol version 6
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> nego token
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> public key auth
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> client nonce
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - [505 bytes]
[18:15:01:599] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - -- NLA_STATE_NEGO_TOKEN --> NLA_STATE_PUB_KEY_AUTH
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - <<----- receiving...
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - <<----- protocol version 5
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - <<----- public key info
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> sending...
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> protocol version 6
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> auth info
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - ----->> client nonce
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - [135 bytes]
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - -- NLA_STATE_PUB_KEY_AUTH --> NLA_STATE_AUTH_INFO
[18:15:01:701] [1922:0a930000] [DEBUG][com.freerdp.core.nla] - -- NLA_STATE_AUTH_INFO --> NLA_STATE_FINAL
[18:15:01:702] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_NLA --> CONNECTION_STATE_MCS_CONNECT
[18:15:01:907] [1922:0a930000] [DEBUG][com.freerdp.core.gcc] - Server rdp encryption method: NONE
[18:15:01:907] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_MCS_CONNECT --> CONNECTION_STATE_MCS_ATTACH_USER
[18:15:01:115] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_MCS_ATTACH_USER --> CONNECTION_STATE_MCS_CHANNEL_JOIN
[18:15:02:255] [1922:0a930000] [DEBUG][com.freerdp.core.info] - Client Info Packet Flags = INFO_MOUSE|INFO_DISABLECTRLALTDEL|INFO_AUTOLOGON|INFO_UNICODE|INFO_MAXIMIZESHELL|INFO_LOGONNOTIFY|INFO_COMPRESSION|INFO_ENABLEWINDOWSKEY|INFO_FORCE_ENCRYPTED_CS_PDU|INFO_LOGONERRORS|INFO_MOUSE_HAS_WHEEL
[18:15:02:255] [1922:0a930000] [DEBUG][com.winpr.timezone] - winpr_get_timezone_from_link: tzid: Europe/Warsaw
[18:15:02:255] [1922:0a930000] [INFO][com.winpr.timezone] - tzid: Europe/Warsaw
[18:15:02:256] [1922:0a930000] [DEBUG][com.winpr.timezone] - tz: Bias=-60 sn='Central European Standard Time' dln='Central European Daylight Time'
[18:15:02:256] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_MCS_CHANNEL_JOIN --> CONNECTION_STATE_LICENSING
[18:15:08:484] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_LICENSING --> CONNECTION_STATE_CAPABILITIES_EXCHANGE
[18:15:08:485] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_CAPABILITIES_EXCHANGE --> CONNECTION_STATE_FINALIZATION
[18:15:08:486] [1922:0a930000] [DEBUG][com.freerdp.core.rdp] - rdp_send_data_pdu: sending data (type=0x1f size=37 channelId=1012)
[18:15:08:486] [1922:0a930000] [DEBUG][com.freerdp.core.rdp] - rdp_send_data_pdu: sending data (type=0x14 size=41 channelId=1012)
[18:15:08:486] [1922:0a930000] [DEBUG][com.freerdp.core.rdp] - rdp_send_data_pdu: sending data (type=0x2b size=57 channelId=1012)
[18:15:08:486] [1922:0a930000] [DEBUG][com.freerdp.core.rdp] - rdp_send_data_pdu: sending data (type=0x27 size=41 channelId=1012)
[18:15:08:591] [1922:0a930000] [DEBUG][com.freerdp.core.rdp] - recv Synchronize Data PDU (0x1F), length: 22
[18:15:08:591] [1922:0a930000] [DEBUG][com.freerdp.core.rdp] - recv Control Data PDU (0x14), length: 26
[18:15:08:591] [1922:0a930000] [DEBUG][com.freerdp.core.rdp] - recv Font Map Data PDU (0x28), length: 26
[18:15:08:592] [1922:0a930000] [DEBUG][com.freerdp.core.connection] - rdp_client_transition_to_state CONNECTION_STATE_FINALIZATION --> CONNECTION_STATE_ACTIVE
[18:15:08:593] [1922:0a930000] [INFO][com.freerdp.gdi] - Local framebuffer format PIXEL_FORMAT_BGRX32
[18:15:08:593] [1922:0a930000] [INFO][com.freerdp.gdi] - Remote framebuffer format PIXEL_FORMAT_RGB16
[18:15:08:594] [1922:0a930000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (rdpdr)
[18:15:08:596] [1922:0a930000] [INFO][com.freerdp.channels.rdpsnd.client] - [static] Loaded mac backend for rdpsnd
[18:15:08:596] [1922:0a930000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (rdpsnd)
[18:15:08:596] [1922:0a930000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (RDMJump)
[18:15:08:596] [1922:0a930000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (RDMCmd)
[18:15:08:596] [1922:0a930000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (RDMLog)
[18:15:08:596] [1922:0a930000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (cliprdr)
[18:15:08:629] [1922:0a930000] [DEBUG][com.winpr.clipboard] - initialized POSIX local file subsystem
[18:15:08:632] [1922:0a930000] [INFO][com.freerdp.channels.drdynvc.client] - Loading Dynamic Virtual Channel ainput
[18:15:08:633] [1922:0a930000] [DEBUG][com.freerdp.channels.drdynvc.client] - register_plugin: num_plugins 1
[18:15:08:633] [1922:0a930000] [INFO][com.freerdp.channels.drdynvc.client] - Loading Dynamic Virtual Channel rdpsnd
[18:15:08:633] [1922:0a930000] [DEBUG][com.freerdp.channels.drdynvc.client] - register_plugin: num_plugins 2
[18:15:08:633] [1922:0a930000] [DEBUG][com.freerdp.channels.drdynvc.client] - create_listener: 1.FreeRDP::Advanced::Input.
[18:15:08:633] [1922:0a930000] [DEBUG][com.freerdp.channels.drdynvc.client] - create_listener: 2.AUDIO_PLAYBACK_DVC.
[18:15:08:633] [1922:0a930000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (drdynvc)
[18:15:08:652] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=6 ChannelName=ECHO
[18:15:08:664] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:664] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - no listener
[18:15:08:665] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:666] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:666] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:669] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:669] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:669] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:670] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:670] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:671] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:672] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:672] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:673] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:673] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:674] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:675] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:675] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:675] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:676] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:676] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:676] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:676] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:688] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=13 ChannelName=AUDIO_PLAYBACK_DVC
[18:15:08:688] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - listener AUDIO_PLAYBACK_DVC created new channel 13
[18:15:08:688] [1922:0b4ec000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (AUDIO_PLAYBACK_DVC)
[18:15:08:688] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - channel created
[18:15:08:688] [1922:0b4ec000] [INFO][com.freerdp.channels.rdpsnd.client] - [dynamic] Loaded mac backend for rdpsnd
[18:15:08:688] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - open_channel: ChannelId 13
[18:15:08:745] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=14 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[18:15:08:745] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - no listener
[18:15:08:747] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:747] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:747] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:747] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:748] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:748] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:749] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:750] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:751] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:751] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:752] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:753] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:753] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:754] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:754] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:754] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:754] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:878] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:879] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:879] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:879] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:880] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:880] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:880] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:883] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_close_request: Sp=0 cbChId=0, ChannelId=14
[18:15:08:883] [1922:0b6ef000] [DEBUG][com.freerdp.core.rdp] - recv Set Error Info Data PDU (0x2F), length: 22
[18:15:08:883] [1922:0b6ef000] [DEBUG][com.freerdp.core] - rdp_set_error_info:freerdp_set_last_error_ex resetting error state
[18:15:08:884] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:884] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:884] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:885] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:885] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] receive [RDPDR_CTYP_CORE | PAKID_CORE_SERVER_ANNOUNCE] [0x000c0001] -> 12
[18:15:08:886] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:886] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:886] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] sending [RDPDR_CTYP_CORE | PAKID_CORE_CLIENTID_CONFIRM] [0x000c0001] -> 12
[18:15:08:886] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] sending [RDPDR_CTYP_CORE | PAKID_CORE_CLIENT_NAME] [0x00000001] -> 40
[18:15:08:887] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:888] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:889] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:889] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:890] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:891] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:892] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:892] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:892] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:892] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:004] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] receive [RDPDR_CTYP_CORE | PAKID_CORE_SERVER_CAPABILITY] [0x00000005] -> 84
[18:15:08:004] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] sending [RDPDR_CTYP_CORE | PAKID_CORE_CLIENT_CAPABILITY] [0x00000005] -> 84
[18:15:08:004] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] receive [RDPDR_CTYP_CORE | PAKID_CORE_CLIENTID_CONFIRM] [0x000c0001] -> 12
[18:15:08:004] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] sending [RDPDR_CTYP_CORE | PAKID_CORE_DEVICELIST_ANNOUNCE] [0x00000000] -> 8
[18:15:08:004] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_close_request: Sp=0 cbChId=0, ChannelId=13
[18:15:08:005] [1922:0b4ec000] [DEBUG][Devolutions.Rdp] - OnChannelDisconnected (AUDIO_PLAYBACK_DVC)
[18:15:08:005] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - close_channel_iface: id=13
[18:15:08:116] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=15 ChannelName=AUDIO_PLAYBACK_DVC
[18:15:08:116] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - listener AUDIO_PLAYBACK_DVC created new channel 15
[18:15:08:116] [1922:0b6ef000] [DEBUG][com.freerdp.core.rdp] - recv Save Session Info Data PDU (0x26), length: 642
[18:15:08:116] [1922:0b4ec000] [DEBUG][Devolutions.Rdp] - OnChannelConnected (AUDIO_PLAYBACK_DVC)
[18:15:08:116] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - channel created
[18:15:08:116] [1922:0b4ec000] [INFO][com.freerdp.channels.rdpsnd.client] - [dynamic] Loaded mac backend for rdpsnd
[18:15:08:116] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - open_channel: ChannelId 15
[18:15:08:117] [1922:0b6ef000] [DEBUG][com.freerdp.core.info] - LogonInfoV2: SessionId: 0x00000002 UserName: [Administrator] Domain: [SQL2012]
[18:15:08:130] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=16 ChannelName=Microsoft::Windows::RDS::Input
[18:15:08:130] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - no listener
[18:15:08:144] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:144] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:144] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:144] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:145] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:145] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:145] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:146] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:146] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:146] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:147] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:147] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:147] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:148] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:148] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:148] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:149] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=17 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[18:15:08:149] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - no listener
[18:15:08:150] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=13 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[18:15:08:150] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - no listener
[18:15:08:168] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:168] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:168] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:169] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:169] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:169] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:170] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:170] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:171] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:171] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:171] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:172] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:172] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:172] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:184] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:184] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:184] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:185] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:185] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:185] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:186] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:186] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:186] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:187] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:187] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:187] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:198] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:198] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:198] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:199] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:199] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:200] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:200] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:201] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:201] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:201] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:204] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:204] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:204] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:205] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:205] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:205] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:206] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:206] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:206] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:207] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:207] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:207] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:207] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:210] [1922:0a7a7000] [DEBUG][com.freerdp.channels.cliprdr.client] - ServerCapabilities
[18:15:08:210] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_close_request: Sp=0 cbChId=0, ChannelId=16
[18:15:08:210] [1922:0a7a7000] [DEBUG][com.freerdp.channels.cliprdr.client] - MonitorReady
[18:15:08:211] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_create_request: ChannelId=18 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[18:15:08:211] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - no listener
[18:15:08:211] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_close_request: Sp=0 cbChId=0, ChannelId=13
[18:15:08:212] [1922:0b4ec000] [DEBUG][com.freerdp.channels.drdynvc.client] - process_close_request: Sp=0 cbChId=0, ChannelId=17
[18:15:08:212] [1922:0a7a7000] [DEBUG][com.freerdp.channels.cliprdr.client] - ClientCapabilities
[18:15:08:212] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] receive [RDPDR_CTYP_CORE | PAKID_CORE_SERVER_ANNOUNCE] [0x000c0001] -> 12
[18:15:08:212] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] sending [RDPDR_CTYP_CORE | PAKID_CORE_CLIENTID_CONFIRM] [0x000c0001] -> 12
[18:15:08:212] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] sending [RDPDR_CTYP_CORE | PAKID_CORE_CLIENT_NAME] [0x00000001] -> 40
[18:15:08:212] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] receive [RDPDR_CTYP_CORE | PAKID_CORE_USER_LOGGEDON] [0x00000000] -> 4
[18:15:08:212] [1922:0a49e000] [DEBUG][com.freerdp.utils.scard] - [rdpdr-channel] sending [RDPDR_CTYP_CORE | PAKID_CORE_DEVICELIST_ANNOUNCE] [0x00000000] -> 8
[18:15:08:213] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:213] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:213] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:213] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:214] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:214] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:214] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:214] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:225] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Alternate Secondary Drawing Order [0x0d] Frame Marker
[18:15:08:225] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:225] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:225] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:226] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:226] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:227] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:227] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
[18:15:08:228] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt
[18:15:08:228] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Primary Drawing Order [0x0d] MemBlt rop=S [0x00cc0020]
[18:15:08:228] [1922:0b6ef000] [DEBUG][com.freerdp.core.update] - Secondary Drawing Order [0x05] Cache Bitmap V2 (Compressed)
All Comments (7)
Hello
This seems to be a known issue with the latest update - can you confirm if disabling clipboard redirection for the session (under RDP > Local Resources > Local Devices and Resources) works around the issue?
I apologize for the inconvenience, we are working on a solution.
Thanks and kind regards,
Richard Markievicz
thank you for quick response.
Yes, disabling clipboard seems to fix this problem.
Another workaround is to put some text into clipboard and it also works with clipboard redirection enabled.
I had this issue on some earlier versions and never linked it to clipboard (the problem always magically disappeared over time).
BR
Paweł H
Hi Pawel
Thanks for confirming.
Just to give a little background: normally, RDM launches the embedded RDP connection using a separate, sandboxed process. This is advantageous because if there is instability in the RDP engine, it won't cause RDM itself to crash.
However, if there's an issue when connecting, the sandboxed process can crash or otherwise fail, but RDM might not know this. There are cases it might assume that the connection failed for some other reason, and it retries the connection again. So you can get stuck in this "Connecting" / "Disconnected" state until the maximum retries is exhausted.
Recent versions of RDM had this issue due to a bug in our interface to the native code. We've fixed that, but the latest update contains some changes to the clipboard that introduce a new bug - however, with the same visible result to the user.
Can you check if you have any relevant crash reports on your system? You can check by opening Console.app (it's in Applications > Utilities) and under the "Crash Reports" section, look for any that reference "FreeRDPSandboxed" or "Remote Desktop Manager".
If you find something, you can right-click and "Reveal in Finder" to locate the crash report on disk, then either send it to me in a PM or by email to rmarkiewicz [at] devolutions.net.
Please let me know if something is not clear
Richard Markievicz
I have only two reports from today, and it crashed when I changed "Use legacy engine" to true and tried to type something on remote desktop.
Anyway those two reports are just sent.
BR,
Paweł H.
Hello Pawel
Thanks for following up with me. I believe we've identified the problem, and I submitted a fix to the RDM macOS team. That should be part of the next release and we'll post here once it's available.
Thanks for your patience,
Richard Markievicz
Hi Pawel,
A version 2022.1.16.0 of RDM is now available with a fix for this issue.
Please, do get back in touch if you are still experiencing any issues with the newer version.
Richard Markievicz
new version works like a charm, RDP sessions are stable.
Thank you for your support!
