Serial Port Connection Freezing Problem
Implemented
After connecting the device with a serial port connection, the operation cannot be performed due to the freezing problem. There is no problem with serial connection to the same device via putty.
There is no serial port connection in the quick connect field. much needed
forum image
All Comments (5)
Could you elaborate on your first point? RDM is freezing when you try to launch a serial port?
As for the second point, we will see what can be done, it's not immediately supported since the Serial Port does not have an host, so I'm pretty sure that even with a custom template, this is not possible at the moment.
Xavier Fortin
When there is a problem with the remote connection while working in the data center, it is necessary to connect it to the device with a cable from the computer.
rdm's serial link is not working. It freezes and gives an error.
What error? Could you provide a screenshot of the error?
Xavier Fortin
Hi freeundismayed,
The next version of RDM Mac (2022.2.X.0) will support using Serial Port in the Quick Connect window.
To do so, you will first need to configure a Serial Port Template:
Once this is done, you should see the template available in the Quick Connect type selector:
The version should be available in the next few weeks.
Xavier Fortin
This should now be fixed in the current version of RDM Mac (2022.2.5.0).
We should have posted an update earlier, it slipped through the cracks. Sorry for that.
Xavier Fortin
Closed
