RDM crashed while editing entry, entry now locked for editing by me. How to unlock?
Hi all,
We use RDM Enterprise with DVLS. Today, I was editing an entry using RDM when RDM crashed. When I reopened it, it now shows the entry is locked for editing and can not edit it from RDM. Editing through the DVLS web interface still works.
How can I unlock this entry?
Thanks,
Patrick
What RDM and DVLS version are you using?
Could you please try to reset the cache on the DVLS web Ui inn Administration - Reset Server Cache and reset the RDM local cache with CTRL+F5 or CTRL+Refresh?
Let me know if that helps.
Érica Poirier
Could you please try to unlock it with right-click on the entry and select Check In?
Let me know if that solve your problem.
Érica Poirier
Hi Patrick,
If you are referring to the Edit Lock:
You can release it from the Opened Sessions -> Entry States tree:
Xavier Fortin
Hi Xavier and Érica,
Thanks for the responses. Xavier's suggestion worked for me.
Solved!
Hi Patrick,
Thank you for your feedback and glad Xavier's solution worked for you.
Érica Poirier
