Double click in vault not working after update
I updated from 2021.2 to 2022.1 and since upgrading i can no longer start new sessions by double clicking on an entry in the vault / tree view.
Only right click launch or enter will start a new session.
I've gone through all the settings but couldn't see anything of use. (For reference I do have Application password protection turned on)
Double click does work fine from the recent tab
Anyone know how to get the double click working again in the vault?
Kind regards
All Comments (5)
Hello Andrews,
Would it be possible for you to go under Help -> About and provide us the exact version number that you are on? The reason why we ask is that a fix was made for an issue related to the double click in the latest versions. While it was related to the "Auto Refresh" it could also apply to this case.
If you would like to try the latest version of RDM without affecting your current environment, you could create a portable installation of the tool. To do so, you will need to do the following:
4- Go in this folder once the .zip file has been extracted and run remotedesktopmanager64.exe
5- Enter your current serial
If you are using the free edition of RDM, please download the .zip file below instead:
https://devolutions.net/remote-desktop-manager/home/thankyou/rdmfreebin
James Lafleur
Hi James,
I am using the free edition, I was using version 2022.1.23.0 - 64-bit, i did check for updates before posting, but checking again today shows there is 2022.1.25.0 - 64-bit
So i just updated and the issue still occurs.
I downloaded the free zip and that works without any issues.
Kind regards
Andrew
Hello Andrew,
Thank you for performing this test!
Since the portable installation of RDM Free works for you, I would recommend closing RDM and then doing the following:
1- Go under your %localappdata% -> Devolutions -> RemoteDesktopManagerFree folder
2- Locate your "remotedesktopmanagerfree.cfg" file and rename it "remotedesktopmanagerfree.old"
3- Once this is done, launch RDM once more
4- Enter your RDM Free serial and see if the same issue occurs.
James Lafleur
Hi James,
Just to confirm that renaming the config file worked to restore the double click functionality.
Many thanks for your help
Andrew
Hello Andrews,
Thank you for your feedback! I am glad to see that it worked for you.
James Lafleur
