Configure connection for Oracle DB
Hello
I can't understand how I have to configure the system to be able to connect to an oracle DB on which to run queries.
Thanks
Sandro
All Comments (1)
Thanks for reaching out.
You can do that using Data Report entry Type. When setting up the Connection string, make sure you specify the proper Data source / Provider in the property.
Technically, the Data Source and Provider are listing what's in the System's ODBC Drivers (ODBC Data Source Administrators)
I hope this helps.
Alex Belisle
