I'm using the most recent versions of RDM and Devolutions server, and I was trying to find out if there is a way to set a specific startup vault, similar to what can be done to set startup datasource?
Because when I choose the DVLS datasource it always opens in the default vault, which since I'm an administrator I can't remove myself from.
Thank you for your question.
Sadly there is no option to specifically set a startup vault in RDM for a any kind of data sources.
When you close RDM and you re-open it, it should open the last vault that was selected. Could you please try it and let me know if that works?
Érica Poirier
I can confirm that it opens the one it was selected before closing.
Thank you for your feedback and glad that the workaround works as expected.
I have submitted a ticket to our engineering team for analysis. Once an update will be available, we will post it here.
Érica Poirier
