SSH Shell Enable Logging Not Working
Implemented
I turn on the feature in the screenshot, but it does not register. log path is empty.
forum image
All Comments (19)
I have reproduced this issue, a ticket has been opened.
Thank you for your report.
Jesse Galarneau
I have fixed the issue, the fix will be live in the next version of RDM Mac.
Jesse Galarneau
Thank you, I'll ask for one more minor edit. With Append log overwrite mode selected, keeps overwriting next log but writes incorrectly.
sample,
I'm typing the shell command after connecting via ssh. then i write another command and i realize i misspelled and delete it and write the correct one. but when I examine the log, it shows wrong as if it was written side by side.
what I do is to type "exit" first and then delete and type "shell" command again. but the result is as below
forum image
and finally the cursor moves up. it goes up more and gets annoying.
forum image
Özgür Yılmaz
it would be as follows, the cursor stays too high.
forum image
For the printable output, this is normal and as designed. It's a dump of all that is written, as it is being written. We do not delete anything from the output.
As for the cursor issue, it is a known issue, but we will release (in the coming months) a new engine for the Terminal that should solve this.
Xavier Fortin
Thank you for the information, when will the new version come out?
Özgür Yılmaz
There is no ETA for this yet. A new version should be released by the start of June, but it's not guaranteed that the new terminal will be available in it. It might come in a following patch.
We'll post back in this post when it is available.
Xavier Fortin
Thanks for your interest and hard work.
Ă–zgĂĽr Yilmaz
Hi freeundismayed,
RDM 2022.1.13.0 is now available with the new terminal engine. It should hopefully resolve your cursor issue.
Xavier Fortin
Oh! The issue with the Printable Output is also resolved.
Xavier Fortin
App won't open after update. I get the following error when I want to ssh
forum image
RDM-Report.zip
Sorry for that, there is an issue with the Syntax Highlighting in the new terminal engine. We are working on a fix.
You can rollback to the previous version in the mean time.
Enterprise version: https://cdn.devolutions.net/download/Mac/Devolutions.RemoteDesktopManager.Mac.2022.1.12.0.dmg
Free version: https://cdn.devolutions.net/download/Mac/Devolutions.RemoteDesktopManager.Free.Mac.2022.1.12.0.dmg
I'll post back here when the fix is available.
Again, sorry for the inconvenience.
Xavier Fortin
The version 2022.1.14.0 is now available and should fix the crash issue.
Xavier Fortin
Thanks, problem solved. I can do ssh connection.
Ozgur Yilmaz
not complete with tab. I want to type sh and complete it with "tab" button but it is not working.
device cisco switch
forum image
forum image
Having the same issue where the tab button in ssh session is not working at all :-(
Hi freeundismayed and simonschuermann,
A version 2022.1.15.0 should be available with a fix for the tab. Could you both confirm that it resolve your issue?
Xavier Fortin
I can confirm that it is working again. Thanks for the fast fix
Glad to hear it!
Please, do not hesitate if you find any other issues.
Xavier Fortin
Closed
