"SSH authentication agent forwarding" does not work to Ubuntu 22.04 LTS
Implemented
Enabling "Allow SSH authentication agent forwarding" in a "SSH Shell" session (under General > Advanced) does not work when connecting to a SSH server on Ubuntu 22.04 LTS.
Every outgoing SSH connection from the Ubuntu machine fails without an explicit error.
Windows (RDM) -> Ubuntu 22.04 (works)
Ubuntu 22.04 -> any other host (does not work)
OpenSSH_8.9p1 Ubuntu-3, OpenSSL 3.0.2 15 Mar 2022
RDM 2022.1.25.0 64-bit
All Comments (4)
In order to gather more information about the issue you are experiencing, I would appreciate if you could follow the steps below to generate logs for your issue.
1. In your SSH session's properties, under the Logs tab, check "Enable Logging"
2. Set "Verbose" to 2
3. Use the ellipsis button to select a path to save your log
4. Make sure that your "Log Mode" is set to "Event"
5. Launch your SSH session and trigger the issue
Once this is done, please send us the log this will create. I will then be able to assign this case to our engineering department in order to find the possible cause of this issue.
Gabriel Degrandpré
Gabriel,
please find attached the requested logfile. This was generated while opening a SSH session to the Ubuntu 22.04 server (successfull) and then doing a "ssh localhost" (not successfull). "Allow SSH agent forwarding" is enabled.
Please note that the same sequence works when using a PuTTY session (which is deprecated) instead of a "native" RDM "SSH Shell" session.
Regards, Thorsten
Ubuntu-22.04.log
Our SSH Shell specialist was able to replicate the issue you describe and located the cause of the issue. He is currently working on a fix.
I will keep you updated as more progress is made on the case!
Gabriel Degrandpré
The issue is fixed with RDM 2022.2.6.0
Closed
