Hi all
Aside from messing with Windows' actual settings (such as screensaver timeout, power settings, etc.) is there some way to have RDM keep my RDP connection from logging me out?
I have a RDP connecting to a Win 10 machine, and if I put RDM with that machine connected and logged in into the background for a bit while I work with other windows in the front, I often come back to the user on that machine logged out and I have to reenter my PW. After a few hundred times of this pattern it gets frustrating.
I'd LIKE if somehow RDM sent some sort of Keep-alive to the machine to prevent that machine from logging out my user; but I want the Windows on that machine to continue behaving with its normal timeouts other wise. So in other words, as long as I'm actively connected via RDM I wont get logged out; but if I close RDM, or manually logout the user on that machine it still behaves as it normally should.
I have tried setting this, but it changes nothing:
The "Keep alive" feature you have tried should be the property to use to achieve what you want. I have taken a look at the RDP Active X documentation and it seems that the "Keep alive" setting we send can be overridden by group policies on your machines.
As far as I know, there are 2 ways that the "keep alive" can be disabled :
Please do let us know if this was your issue or not.
Best Regards,
Michaël Beaudin
Hi Michael
Ty for the help. I checked that value in the policy editor and it showed this:
I went ahead and specifically enabled it, and set it to 60 (to match the 60 that I set in RDM for that connection; does that sound right, or should I set the one on the machine to a lower number?)
Aside from that, I will report back to see if that took care of everything. =)
Quick side question: mind if i ask which forum software this is? It's nice. I'm currently sniffing around all the forum/cms software to try and decide on one to use for a forum of my own down the road. I tried looking in the inspector for a hint but don't see anything. =)
I will forward the comments to our dev team because it's our own custom development.
I can see that you did not have anything configured there so it is doubtful that the setting sent by RDM was overridden. I have spoken with someone on our team who is more knowledgeable about RDP and he says that the "Keep alive" is not the same as what we could call a "Keep awake" that I believe is what you want.
There also seems to be no existing setting we can pass to RDP to achieve what you would want. Therefor, we would need to find a way to work around this issue. We have created a ticket for this and will keep you updated on the progress.
Michaël Beaudin
Ok, TYVM Michael.
