Sessions using Edge
When ever I open a web session from RDM which uses Edge I get this error pop up?
Click OK and the session runs fine.
Any ideas how I correct this?
Thanks
Iain
All Comments (2)
I suspect this has to do with how your Edge entry is configured. Can you verify if you have "clear cache on startup"? If you do, could you make sure you also check "private session (incognito)" for this entry? What I think happens in this case, is since you have "clear cache on startup" but you don't run in incognito, RDM is unable to clear the cache since you already have another edge entry opened.
Perfect thank you, that has resolved the issue.
Thanks
Iain
