Allow using backtick key for custom keyboard shortcuts
Implemented
It would be very helpful to allow using the backtick "`" key (just above TAB) for keyboard shortcuts. It's very efficient, because you can handle it with just one hand, and it's almost unused. I would certainly use it for the "Filter" command. I tried CTRL+Q, but it conflicted with the same key combination within session, so had to unset it. All combinations of modifiers with this key could be useful.
Thanks in advance.
All Comments (8)
I will create an enhancement request for that I don't think it will be hard to add.
Thank you very much David!
These new shortcut combinations will be available starting with RDM 2022.1.18.0. In the selection you should look for the "OemTilde" key, for example "Ctrl+OemTilde".
Thank you very much!
Just to let you know - I installed new version of RDM and it works fantastic! Thanks!
Glad this works for you!
I just started using RDM for Android to connect to a Mac. It works great but I noticed that I can't type the backtick character. I did a quick search and found this thread. Is it related? I haven't done anything to configure shortcuts and I don't see where I would change anything in the app.
Hello Andrew,
This thread was for RDM Windows, but I was able to replicate your issue with RDM Android and an ARD session.
I will open an internal ticket for the engineering team and keep you posted.
Richard Boisvert
