WALLIX Bastion PAM solution
Hello, is there any plan for integration with WALLIX Bastion PAM solution
Thank you
Ales
All Comments (2)
I you search our forum for the term Wallix, you will see that it had never been mentioned in an integration request. It may have been requested a few times via email, but its not really a hot topic.
As you can see from our "credential" section of RDM, we work with anyone and everyone because it adds tremendous value to the ecosystem. In the case of PAM vendors, sadly we've flown through areas of turbulence because they sometimes see us as competitors, or even worse, they are sure that ALL of your needs are met by their solution, all the while severely impacting your productivity.
David, our CEO, as stated that for PAM vendors, we will only work when the relationship is one of partners. Integrating with a PAM solution is a lot of work, and usually requires a minimum level of support for our engineers from the vendor.
That being said, we will do a preliminary analysis as to the feasibility of such an integration, but we often rely on the common customer to as their contacts at the vendor to help with the integration. Are you in a position to do that?
Maurice
thanks for the comprehensive answer. Unfortunately we are not in a position to ask suppliers to cooperate.
Best Regards
Ales Husnik
Closed
