Implemented
F6/F7 not changing correctly
Hi
After updating to 2022.1.16.0 64-bit when pressing F6 or F7 the navigaion tree isn't changed. The tab icon in the bottom switches between "Vault" and "User vault" but the tree view part isn't changing.
Clicking the tab icon works.
Regards Lars
Remote Desktop Manager connected with Devolutions Server running newest versions.
------------------------Signature------------------------
Sorry if any of above sounds harsh or provoking, it is NOT meant as such, but I have Asperger's and don't always know.
My intentions is always to be friendly.
All Comments (2)
I just did a quick patch for this issue: Could you try to overwrite your installation with this content?
https://cdn.devolutions.net/download/Devolutions.RemoteDesktopManager.Bin.2022.1.16.0.zip
Thank you very much ! - I confirm that this works, and it's tested on 3 installations :)
