RD Gateway problem when in Open extarnal
We have problems connection to servers with RDP external through a Microsoft RD Gateway we log on to with a password from the user vault.
If I choose to Connect to an RDP session from RDM (Open external)
 I gett:
If I choose to use embedded, it works.
If I rename the Password entry in my user vault, then I am asked for a username and password by windows then it works connection external.
The most of our users use embedded, but those who use it external this a problem for some of them, to make this even better
they can have days that it works, not everybody at the same time.
I think this started after upgrading to 2021.2.x
Windows 10 and windows 11
Remote desktop manager Enterprise edition 2021.2.26
Datasource Azure SQL
All Comments (13)
Could you try to toggle this setting?
When I turn it off, I'm asked for credentials by the Microsoft RD gateway.
Thank you for your swift reply!
If you save your credentials in your RDP entry directly, without using those from your User Vault, do you experience the same issue when the RDP connection is launched externally?
James Lafleur
Yes , I get the same problem when configuring the Usernam and password on the RDP entry directly.
The next time this issue occurs, could you please ask your users to go under Help -> Profiler -> Debug Only and set the debug level to 1?
Once this is done, ask them to launch the connection again and provide us with the logs that will be created in the Profiler Window.
Once this is done, make sure to set your debug level back 0. These logs can be sent to me via private message.
James Lafleur
I do not get anything in the log when set the debug level to 1 and connect to a server open with parameters open(external).
Can it be a setting that I missed?
I have added a new debug log and this will be in the next minor update. The problem with external RDP is that we can't set the credentials directly and we have to set it in the Windows Credential Vault.
I do not think this is a username/password problem, I base this on that if I change the password in the password entry in my personal vault, I get this:
If I then type my username and password I get logged inn.
But when the username and password is correct in my personal vault I get:
And I have found that if you change:
HKEY_CURRENT_USER\Software\Microsoft\Terminal Server Client
From 1 to 0 You get logged inn,
but then you have the problem that you may have to tray 10 times to log on to a server, so that is not a god solution.
While reading your reply, the workaround you have found was what I was about to suggest. This is explained in detail here: https://kb.devolutions.net/rdm_microsoft_rdp_remote_computer_error.html
Since this workaround does not seem to suit your needs, I would recommend trying the first solution mentioned in the above link instead. Let us know if that works for you.
James Lafleur
We have the Activate network level authentication checked and it does not work.
Would you be interested in having a remote session? We could take a closer look at your current configuration and see what can be done. If you are interested, just let me know and I will open a support ticket on your behalf in order to schedule a session with you.
James Lafleur
Yes please do.
Thank you! Your case number is 00002286 and you should receive a reply from me shortly.
Once this issue has been sorted, I will post the solution on this forum thread.
James Lafleur
