The cloud PCs are hosted at https://windows365.microsoft.com/
I can connect with a web client or MS Remote Desktop App for Windows. I would like to know if I can connect using the Remote Desktop Manager.
I will be grateful for suggestions.
Ed Santos
If you are able to connect to these PCs using Microsoft Remote Desktop, you should also be able to connect from RDM. In fact, in the properties of RDP sessions in RDM, if you set the Display option to "External", you will use Microsoft Remote Desktop itself rather than the default embedded RDP engine. This should allow you to have the same behavior in RDM as you get outside of it.
Don't hesitate to let me know if you have any additional questions on this topic!
Gabriel Degrandpré
Gabriel.
Thanks for replying. I don't have the information for an RDP as usual.
The information is based on a workspace feed that the MS Remote Desktop app can read after I authenticate.
Could you provide steps or screenshots for your suggestion?
regards!
I had a chat with our engineering department and your request it’s not something that we can support for now. Microsoft has not documented how we could support this, so as of now, there’s nothing we can do.
Jeff.
Thanks for checking!
Regards.
Ed.
