Selecting authentication credentials for RDP sessions, paired with Bitwarden
I have 3 separate credentials, which are saved in Bitwarden. I've activated the RDM plugin and authenticate seamlessly on my RDP connections. However, a large chunk of my RDP connections require any of the 3 saved credentials. I was looking an option to select which save credential would be utilized for the session.
For example, I have a RDP session. Most of the time, I use the basic user-level account. Occasionally, I need to login with server admin level credentials. Once in a while, I would need to use the enterprise admin credentials. I'm looking for a way to select the correct save credential, prior to making the RDP connection.
I suppose I could create one RDP connection per login, but I don't wish to triple the number of connections, which number over 2,000.
Ideas?
All Comments (1)
With your Bitwarden entry, you could set "Always Prompt with List" and then link the Bitwarden entry to your RDP.
This way, when you will launch your RDP session, you will get a prompted list of you credentials and choose the desired one :
Best Regards,
Etienne Lord
