I think I might be missing something with the dynamic credential linking and Passwordstate.
I have created a passwordstate entry with standard API and chosen my Password List. It shows me the password list and passwords fine, so the API works.
But if I choose this password for a RDP entry it just gives me a password prompt then trying to open a session. If I choose custom credentials and manually type in the credentials it works fine.
I have also tried with setting the password directly in the passwordstate entry and chosen that in the RDP entry. Same issue. :(
The API is allowed to retrieve passwords.
One of our engineering came across this topic and has let me know that using Dynamic Credential Linking requires the option "Always prompt with list" to be enabled in the PasswordState entry. I would like to verify if enabling it changes the behavior for you.
I would also like to verify the version of RDM you are currently using?
Gabriel Degrandpré
Hello Gabriel,
This did the trick. Thank you!
Im using version 2021.2.28.0 64-BIT
//Mads
