CyberArk PSM connection with dynamic connection component
Hi Everyone,
I am looking at a way to avoid duplication of accounts for multiple connection components.
Is there a way to setup a CyberArk PSM Connection entry where we can select the connection component at connection.
Currently to do this I would need to edit the entry to update to the desired connection component.
I'd like to fast track that if possible.
Right click to pick connection component if I don't want to use the default one would be perfect.
Cheers,
Chris D
All Comments (1)
Hello Chris,
If you are using CyberArk 12.1 in conjonction with RDM 2021.2.20 and above, you can instead use the the CyberArk Dashboard to select a priviliegied account and connect to a host using the protocol you desire. We are currently making a KB for it, but here is the relevant section for your question:
Connecting to a host
After selecting the account you wish to use, you can either use the buttons above the accounts, or right-click and select the appropriate connection type
forum image
 You will then see a list containing the host you wish to connect to, for example an RDP session.
forum image
Let us know if you need details on how to configure the CyberArk dashboard entry.
Richard Boisvert
