Smart Sizing - Default Setting
Hi, is there a setting to enable Smart Sizing by default for all tabs? I've been doing it per tab and it's getting annoying. I'd like to enable it for everything all the time.
All Comments (2)
It can be configured by default in RDM under File > Options
You can also have a default template for RDP, this will benifit new RDP sessions created: File > Templates > Default Session > RDP:
Richard Boisvert
You should be able to do this via File > Options > Types > Remote Desktop > Screen Sizing Mode set to Smart Sizing. This will make the Default option on RDP sessions Smart Sizing.
Another option, if you already have some configured, you could select all your RDP Sessions and under Edit tab > Batch edit > Edit (Session Type Settings). Here you would be able to change on a mass scale all Display information for all sessions selected.
Eric St-Martin
