Cisco SSH Post Login Command Not Running
Good evening everyone,
We have a Cisco switch we are accessing via SSH. On this session, we have a post login command that runs to show us some ports. When we login using RDM on Windows, it works perfectly as expected. However, when we run the same session in RDM on IOS, the command does not run. Is this a limitation of the IOS version?
Thanks
All Comments (2)
This issue has been fixed and it will be in the next release.
Best Regards,
Nicolas Dufour
Awesome :) Thanks
Closed
