Hello!
After updating the "Remote Desktop Manager" application on Android 10.0, the migration window began to appear at startup. The "Migration" and "Skip" buttons do not work.
How to fix the application without losing data?
Two of the data sources that you use are shared (MySQL and DODB) and you will not lose data from those. Just keep the application on your device and we will get back to you tomorrow. We are on a Holiday here in Canada and our office is closed. Since you cannot get into the application and you are stuck at the migration window, we will probably have to send you a special build.
Best Regards,
Nicolas Dufour
Hi Nicolas,
Yes, it is. Shared data sources are available, data is OK. However, we are experiencing difficulties in accessing the .xml source "Local data source". It is located in the "/data/user/0/com.devolutions.remotedesktopmanager" folder and we cannot access it even through adb.
Thank you very much for your understanding. I will be happy to wait for your answer and will be very glad to help.
Best Regards,
Gleb Grebenchikov
Can you:
1- Try to migrate your data sources
2- Tap on the logs button.
3- Send us a few screenshots of the logs.
This should help us understand why the migration is not working.
Best Regards,
Nicolas Dufour
