Navigation - Custom Field 1 and Custom Field 2 are Missing
All Comments (5)
Forgot to mention, I added the custom 1 and 2 columns then hid them, after hiding them I do not see them to re-add them
Could you try the following:
  • Close RDM
  • Navigate to %localappdata%\Devolutions\RemoteDesktopManagerFree
  • Rename the remotedesktopmanager.ext file into remotedesktopmanager.old
  • Restart RDM
Let us know if the columns are back for addition.
I found the file in the RDM directory ( using the portable version ), after renaming the file and restarting RDM I do not see the Custom fields.
If you right-click on the root folder, select properties and then, select User Interface, is it possible that you have renamed your Custom Field for something else?
forum image
Closed
