I am trying to set up a dynamic port forwarding, using the "SSH port forward" connection type, but when sending requests to an API on the remote end, I get the following message.
An exception occurred while attempting to connect to: https://user-mgmt.nbi.welktx08vzwvnom-y-nk-ems-00.vcp.vzwnet.com/auth/realms/NEO/protocol/openid-connect/token
The exception was:
Unsupported or unrecognized SSL message
Root cause:
SSLException: Unsupported or unrecognized SSL messageI enabled verbose logging on the connection, and these are the messages I am seeing at the same time.
[8/31/2021 5:34:19 AM] Sending forward channel open request: 2/- user-mgmt.nbi.welktx08vzwvnom-y-nk-ems-00.vcp.vzwnet.com:443
[8/31/2021 5:34:20 AM] Received channel open confirmation: 2/2 WS 200000/2097152 MPS 32000/32768
[8/31/2021 5:34:20 AM] Successfully established connection localhost:9081 -> user-mgmt.nbi.welktx08vzwvnom-y-nk-ems-00.vcp.vzwnet.com:443
[(-549455608) Unknown error.]
[8/31/2021 5:34:20 AM] Sending channel EOF: 2/2
[8/31/2021 5:34:20 AM] Sending forward channel open request: 3/- user-mgmt.nbi.welktx08vzwvnom-y-nk-ems-00.vcp.vzwnet.com:443
[8/31/2021 5:34:20 AM] Error writing to local end of tunnel
[(10053L) An established connection was aborted by the software in your host machine.]
[8/31/2021 5:34:20 AM] Sending channel close request: 2/2
[8/31/2021 5:34:20 AM] Received channel close request: 2/2
[8/31/2021 5:34:20 AM] Channel is closed: 2/2When setting up the same tunnel with Putty, it works as expected.
Is there a setting I perhaps overlooked?
BTW, it works as expected with the MacOS version of RDM.
Thanks in advance!
I will open a ticket so our engineering team can analyze our logs and let us know what they tell us. But before I do, I would like to gather some additional information about your RDM environment.
What version of RDM do you currently use?
What is the type of data source you use?
Also, just to make sure that your logs contain the information our engineering team needs, I would like to verify if your logs were generated with the Verbose level set to 2. If not, we would need your logs again with that level.
Gabriel Degrandpré
