Display Settings RDM Entry
Hi Support
When i click on an Entry, i can only view the parameters by right click on the entry and going to properties.
Is it possible, to display the properties on the right pane automaticaly when i highlight an entry?
I didnt found any related setting in options pane.
forum image
Thanks a lot,
Andreas
Hello Andreas,
This is not exactly what you're looking for but you can add the "Overview" to your "Dashboard" this will allow you to have a small "Overview" of the entry "Properties". That being said it will not allow you to edit them, the only way to do that would be to access the entry "Properties" by either doing a "Right-click" -> "Properties" on the entry in the "Navigation Pane" or pressing the "Properties" button under the "Actions".
To add the "Overview" tab simply perform a "Right-click" on one of your existing tabs in the "Dashboard" and check the "Overview" option.
forum image
Let me know if this helps,
Samuel Dery
Hello
My whole Dashboard was missing, and I looked for an option to activate it again in the view. But there is no Dashbaord option to toggle it on or off anymore, I was able to do it with Alt + F6, but why is there no option anymore (or am I blind):
"To enable the dashboard in Remote Desktop Manager (RDM), go to View > Dashboard or use the keyboard shortcut Alt + F6. You can also customize the dashboard's appearance by going to File > Settings > User Interface > Dashboard. "
Over the years it's been changed to the "window" tab rather than the "view" tab:
There's also the search text field in the ribbon that can help you find different settings.
For the quote about where to find it, did you find this in our documentation? If so, can you link the page, I will ask our documentation team to update it so the information is accurate.
Closed
