Embedded Script View for Script Repository
Implemented
I have started putting a lot of powershell scripts in RDM. This is a good place to put them in my opinion and they can be used in a flexible manner. Beyond that it is becoming something of a library. I have a vault dedicated to powershell, VB and batch scripts. Sometimes I will copy specific scripts from the Script Vault to a customer vault.
HOWEVER, if there is one thing I that would be super useful and that would be the ability to view a script without having to open the properties and navigate to the 'embedded' location. In some cases I might see a script and want to copy and paste it (or certain pieces) into a powershell window. Maybe a tab like "Documentation" where it shows the text of the script. Color coding would be awesome (like the way the ISE color codes).
Of course it is possible to duplicate effort by pasting it into the documentation location TOO but that gets clunky when keeping things updated. A quicker way to see and copy a script that is embedded would be great.
To say can't is to fail before you begin
All Comments (4)
Hello Bill,
Thanks for the request, I think it's a great idea. I've opened a ticket for this.
Excellent. Thank you!
Sorry for the delay, but the View Script button should be accessible through the dashboard when the version 2022.2.10 comes out. This should work on any macro/script entry that has an embedded script.
Jafran Majeau
Wow. You guys are awesome! Thank you!
