Hello
We are new to RDM and are now in the progress of migrating to use RDM company wide.
We would like to use automatic checkout to avoid conflicting sessions (multiple users trying to use the same entry), but we need the offline mode since certain usergroups need to be able to use RDM without internet access or in a brake the glass scenario where network connection is gone. Whenever we try to access an entry in offline mode, we are unable to even see the password due to the checkout policy.
Is there a way we can use offline mode and still avoid the possibility that one users kicks another user out of a session?
Thanks in advance and have a great weekend!
With kind regards,
Nick
Unfortunately, both features are incompatible. In order for the checkout feature to work, you need to have access to the database and be online, or else other users won't be able to see that the connection is already in use.
James Lafleur
Hello James
Thank you for the clarification. I hope you had a great weekend.
We had hoped that in offline mode RDM would ignore the check-out. I see why it requires an online connection.
I hope that in the future, the option to ignore the automatic checkout when offline comes available. When an user is offline, they probably won't use a remote connection and will be working directly on the host, making the checkout feature irrelevant. This would be a great addition for our use-case.
If needed, I would gladly elaborate this request via direct messaging.
With kind regards,
Nick
Hello Nick,
Thanks for the feedback. Honestly I think it wouldn't be too complicated to allow this. I'm thinking we could add an option in the dropdown that would basically mean "automatic (when available)". This is how the "optional" mode works I believe (you can checkout if you'd like, but you're not required to), except it doesn't checkout automatically.
I've opened a ticket to add this to RDM in the future. We'll update this thread once it's available.
Hello Hubert
Thank you! It would be great if that option could be added as you described.
We are looking forward to hear about the update when it's available.
Thanks once again.
With kind regards,
Nick
Hello
Are there any updates regarding this matter?
WIth kind regards,
Nick
Our plan currently is to be able to add this to the next major RDM version, planned for release early next year.
Hello Hubert
Thank you for the update.
We are looking forward to the release of this feature.
With kind regards,
Nick
Hello Hubert
Was the compability implemented in the 2022 release?
I would like to verify before testing since we are using it now in production and don't want to cause the issue we had during testing in production.
Furthermore I was wondering how it will react when the credentials used for the connection and the connection itself are separated entries in RDM. Will it only block the connection, or the credential entry, or both?
With kind regards,
Nick
Hello Nick,
Unfortunately we did not get to add this in RDM 2022.1, but we have put it on the roadmap for RDM 2022.2 for this summer (around June). This is the kind of change that we really have to synchronize our whole product line to properly support the option so it's more fitting for a major update than an incremental patch.
Regarding linked credentials, I performed the test and when the checkout is configured in "automatic" mode on both entries, it will checkout both the entry itself as well as the credential. The behavior is planned to be the same with the "automatic (if available)" option, but only perform the checkout if you are not in offline mode, of course.
Thank you. I'll be looking forward to the update.
Hi Nick,
We have added this feature internally. It should be available starting with version 2022.2
Jean-Francois Duchesne
Thank you
