Im using RDM 2021.1.36.0 64bit.
When is create an rdp with a gateway the session starts and then disappears.
I've asked the customer if he can send me an rdp file to check the settings, when i dubbel click on the file i received i can connect to the server if i import the rdp file into rdm and select import RDP content then i can't connect to the server. When i link the rdp file in rdm i can connect to the server.
Can you help me to find out why it don't work when i import RDP content.
Below are the settings form the rdp file i received form the customer, the hostnames are changed so the info of the customer is not displayed
redirectclipboard:i:1
redirectprinters:i:0
redirectcomports:i:0
redirectsmartcards:i:0
devicestoredirect:s:*
drivestoredirect:s:
session bpp:i:32
prompt for credentials on client:i:1
server port:i:3389
allow font smoothing:i:1
promptcredentialonce:i:1
videoplaybackmode:i:1
audiocapturemode:i:1
gatewayusagemethod:i:2
gatewayprofileusagemethod:i:1
gatewaycredentialssource:i:0
full address:s:XXXXXXX.XXXXX.com
gatewayhostname:s:XXXXXXX.XXXXX.com
workspace id:s:XXXXXXX.XXXXX.com
use redirection server name:i:1
loadbalanceinfo:s:tsv://MS Terminal Services Plugin.1.XXX
use multimon:i:1
alternate full address:s:XXXXXXX.XXXXX.com
signscope:s:Full Address,Alternate Full Address,Use Redirection Server Name,Server Port,GatewayHostname,GatewayUsageMethod,GatewayProfileUsageMethod,GatewayCredentialsSource,PromptCredentialOnce,RedirectPrinters,RedirectCOMPorts,RedirectSmartCards,RedirectClipboard,DevicesToRedirect,DrivesToRedirect,LoadBalanceInfo
signature:s:AQABAAEAAAClGAAAMIIYoQYJKoZIhvcNAQcCoIIYkjCCGI4CAQExDzANBglghkgB ZQMEAgEFADALBgkqhkiG9w0BBwGgghaTMIIENjCCAx6gAwIBAgIBATANBgkqhkiG 9w0BAQUFADBvMQswCQYDVQQGEwJTRTEUMBIGA1UEChMLQWRkVHJ1c3QgQUIxJjAk BgNVBAsTHUFkZFRydXN0IEV4dGVybmFsIFRUUCBOZXR3b3JrMSIwIAYDVQQDExlB ZGRUcnVzdCBFeHRlcm5hbCBDQSBSb290MB4XDTAwMDUzMDEwNDgzOFoXDTIwMDUz MDEwNDgzOFowbzELMAkGA1UEBhMCU0UxFDASBgNVBAoTC0FkZFRydXN0IEFCMSYw JAYDVQQLEx1BZGRUcnVzdCBFeHRlcm5hbCBUVFAgTmV0d29yazEiMCAGA1UEAxMZ QWRkVHJ1c3QgRXh0ZXJuYWwgQ0EgUm9vdDCCASIwDQYJKoZIhvcNAQEBBQADggEP ADCCAQoCggEBALf3GjPm8gAELTngTlvtH7xsD821+iO2zt6bETOXpClMfZOfvUq8 k+0DGuOPz+VtUFrWlymUWoCwSXrbLpX9uMq/NzgtHj6RQa1wVsfwTz/oMp50ysiQ VOnGXw94nZpAPA6sYapeFI+eh6FqUNzXmk6vBbOmcZSccbNQYArHE504B4YCqOmo aSYYkKtMsE8jqzpPhNjfzp/haW+710LXa0Tkx63ubUFfclpxCDezeWWkWaCUN/cA Lw3CknLa0Dhy2xSoRcRdKn23tNbE7qzNE0S3ySvdQwAl+mG5aWpYIxG3pzOPVnVZ 9c0p10a3CitlttNCbxWyuHv77+ldU9U0WicCAwEAAaOB3DCB2TAdBgNVHQ4EFgQU rb2YejS0Jvf6xCZU7wO94CTLVBowCwYDVR0PBAQDAgEGMA8GA1UdEwEB/wQFMAMB Af8wgZkGA1UdIwSBkTCBjoAUrb2YejS0Jvf6xCZU7wO94CTLVBqhc6RxMG8xCzAJ BgNVBAYTAlNFMRQwEgYDVQQKEwtBZGRUcnVzdCBBQjEmMCQGA1UECxMdQWRkVHJ1 c3QgRXh0ZXJuYWwgVFRQIE5ldHdvcmsxIjAgBgNVBAMTGUFkZFRydXN0IEV4dGVy bmFsIENBIFJvb3SCAQEwDQYJKoZIhvcNAQEFBQADggEBALCb4IUlwtYj4g+WBpKd QZic2YR5gdkeWxQHIzZlj7DYd7usQWxHYINRsPkyPef89iYTx4AWpb9a/IfPeHmJ IZriTAcKhjW88t5RxNKWt9x+Tu5w/Rw56wwCURQtjr0W4MHfRnXnJK3s9EK0hZNw EGe6nQY1ShjTK3rMUUKhemPR5ruhxSvCNr4TDea9Y355e6cJDUCrat2PisP29owa QgVR1EX1n6diIWgVIEM8med8vSTYqZEXc4g/VhsxOBi0cQ+azcgOno4uG+GMmIPL HzHxREzGBHNJdmAPx/i9F4BrLunMTA5amnkPIAou1Z5jJh5VkpTYghdae9C8x49O hgQwggV0MIIEXKADAgECAhAnZu5W60nzjqvXcKL8hN4iMA0GCSqGSIb3DQEBDAUA MG8xCzAJBgNVBAYTAlNFMRQwEgYDVQQKEwtBZGRUcnVzdCBBQjEmMCQGA1UECxMd QWRkVHJ1c3QgRXh0ZXJuYWwgVFRQIE5ldHdvcmsxIjAgBgNVBAMTGUFkZFRydXN0 IEV4dGVybmFsIENBIFJvb3QwHhcNMDAwNTMwMTA0ODM4WhcNMjAwNTMwMTA0ODM4 WjCBhTELMAkGA1UEBhMCR0IxGzAZBgNVBAgTEkdyZWF0ZXIgTWFuY2hlc3RlcjEQ MA4GA1UEBxMHU2FsZm9yZDEaMBgGA1UEChMRQ09NT0RPIENBIExpbWl0ZWQxKzAp BgNVBAMTIkNPTU9ETyBSU0EgQ2VydGlmaWNhdGlvbiBBdXRob3JpdHkwggIiMA0G CSqGSIb3DQEBAQUAA4ICDwAwggIKAoICAQCR6FSS0gpWsawNJN3Fz0RndJkrN6N9 I3AAcbxT38T6KhKPS38QVr2fcHK3YX/JSw8Xpz3jsARh7v8Rl8f0hj4K+j5c+ZPm NHrZFGvnnLOFoIJ6dq9xkNfs/Q36nGz637CC9BR++b7Epi9Pf5l/tfxnQ3K9DADW ietrLNPtj5gcFKt+5eNu/Nio5JIk2kNrYrhV/erBvGy2i/MOjZrkm2xpmfh4SDBF 1a3hDTxFYPwyllEnvGfDyi62a+pGx8cgoLEfZd5ICLqkTqnyg0Y3hOvozIFIQ2dO ciqbXL1MGyiKXCJ7tKuY2e7gUYPDCUZObT6Z+pUX2nwzV0E8jVHtC7ZcryxjGt9X yD+86V3Em69FmeKjWiS0uqlWPc9vqv9JWL7wqP/0uK3pN/u6uPQLOvnoQ0IeidiE yxPx2bvhiWC4jChWrBQdnArncevPDt09qZahSL0896+1DSJMwBGB7FY79tOi4lu3 sgQiUpWAk2nojkxl8ZEDLXB0AuqLZxUpaVICu9ffUGpVRr+goyhhf3DQw6KqLCGq R84onAZFdr+CGCe01a60y1Dma/RMhnEw6abfFobg2P9A3fvQQoh/ozM6LlweQRGB Y84YcWsr7KaKtzFcOmpH4MN5WdYgGq/yapiqcrxXStJLnbsQ/LBMQeXtHT1eKJ2c zL+zUdqnR+WEUwIDAQABo4H0MIHxMB8GA1UdIwQYMBaAFK29mHo0tCb3+sQmVO8D veAky1QaMB0GA1UdDgQWBBS7r34CPfqm8TyEjq3uOJjs2TIy1DAOBgNVHQ8BAf8E BAMCAYYwDwYDVR0TAQH/BAUwAwEB/zARBgNVHSAECjAIMAYGBFUdIAAwRAYDVR0f BD0wOzA5oDegNYYzaHR0cDovL2NybC51c2VydHJ1c3QuY29tL0FkZFRydXN0RXh0 ZXJuYWxDQVJvb3QuY3JsMDUGCCsGAQUFBwEBBCkwJzAlBggrBgEFBQcwAYYZaHR0 cDovL29jc3AudXNlcnRydXN0LmNvbTANBgkqhkiG9w0BAQwFAAOCAQEAZL+D8V+a hdDNuKEpVw3oWvfR6T7ydgRu8VJwux48/00NdGrMgYIl08OgKl1M9bqLoW3EVAl1 x+MnDl2EeTdAE3f1tKwc0DurFxLW7zQYfivpedOrV0UMryj60NvlUJWIu9+FV2l9 kthSynOBvxzz5rhuZhEFsx6ULX+RlZJZ8UzOo5FxTHxHDDsLGfahsWyGPlyqxC6C y/kHlrpITZDylMipc6LrBnsjnd6i801Vn3phRZgYaMdeQGsj9Xl674y1a4u3b0b0 e/E9SwTYk4BZWuBBJB2yjxVgWEfb725G/RX12V+as9vYuORAs82XOa6Fux2OvNyH m9Gm7/E7bxA4bzCCBggwggPwoAMCAQICECsuburZdTZsFIpu26N8jAcwDQYJKoZI hvcNAQEMBQAwgYUxCzAJBgNVBAYTAkdCMRswGQYDVQQIExJHcmVhdGVyIE1hbmNo ZXN0ZXIxEDAOBgNVBAcTB1NhbGZvcmQxGjAYBgNVBAoTEUNPTU9ETyBDQSBMaW1p dGVkMSswKQYDVQQDEyJDT01PRE8gUlNBIENlcnRpZmljYXRpb24gQXV0aG9yaXR5 MB4XDTE0MDIxMjAwMDAwMFoXDTI5MDIxMTIzNTk1OVowgZAxCzAJBgNVBAYTAkdC MRswGQYDVQQIExJHcmVhdGVyIE1hbmNoZXN0ZXIxEDAOBgNVBAcTB1NhbGZvcmQx GjAYBgNVBAoTEUNPTU9ETyBDQSBMaW1pdGVkMTYwNAYDVQQDEy1DT01PRE8gUlNB IERvbWFpbiBWYWxpZGF0aW9uIFNlY3VyZSBTZXJ2ZXIgQ0EwggEiMA0GCSqGSIb3 DQEBAQUAA4IBDwAwggEKAoIBAQCOwgIZ4aBZpOs4NY0s/QHQ00nAZMcLYgVFFjqo oMAMAn8dzNvEoW13A6MPhvnjBpw+C4GKm0kbrQO++kvbjCDt1c5eZY4+Da9MwrC3 RV5SLzTeSCRktEGuAJf3vmfentB6p1OAO3yt9ZZVb5dHCnyFiyKXjbOE4JZX0HAY YJaP7i0Hk52husrRzXvpxCqaKCGRTW+STyWl8no13SbcRqXQrFk1jP9OkUNQP1mT HmxRIe5YFKv+dVB4PkywHIYT+muYvOA7lB6FUtwDkyQYbssnUUXmcN4lQ6QN4Uql 7bZ+yM1t7i4dJ3Nd3EUwgKrjskELr71Eh9q55Rudf67lhYKlAgMBAAGjggFlMIIB YTAfBgNVHSMEGDAWgBS7r34CPfqm8TyEjq3uOJjs2TIy1DAdBgNVHQ4EFgQUkK9q OpRaC9iQ6hJWc99DtDoo2ucwDgYDVR0PAQH/BAQDAgGGMBIGA1UdEwEB/wQIMAYB Af8CAQAwHQYDVR0lBBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCMBsGA1UdIAQUMBIw BgYEVR0gADAIBgZngQwBAgEwTAYDVR0fBEUwQzBBoD+gPYY7aHR0cDovL2NybC5j b21vZG9jYS5jb20vQ09NT0RPUlNBQ2VydGlmaWNhdGlvbkF1dGhvcml0eS5jcmww cQYIKwYBBQUHAQEEZTBjMDsGCCsGAQUFBzAChi9odHRwOi8vY3J0LmNvbW9kb2Nh LmNvbS9DT01PRE9SU0FBZGRUcnVzdENBLmNydDAkBggrBgEFBQcwAYYYaHR0cDov L29jc3AuY29tb2RvY2EuY29tMA0GCSqGSIb3DQEBDAUAA4ICAQBOK3ZPkhxiNom6 d8EnBfQc1kSdqZo+qtVmZgE+6knmojW8+vbdlY6ZNZgONhh1sd3dUHJ8rtx3iM4P 95AgyqNnLh9Wf3vhROpClcRdDQFQRhXygYlZbIrdjPESoY06QoqY+Es0eyc7CLRv JDtynWN0WDwabD9PxxGayKj1tTfvEEXGbNngXpUms+uto7nufwyaZjVzMmBO5d2K YSxuUhF3aJbTGHVRFQAbdIjd4cc4BEMo6Rb92QXUXUcnYNb7ODtscqKU+EIa3+1v BoxFwgYAquTo3Nm14XN47PYj3NHdbI4aj6XqVHyWt8P+VY6NSV78ZLvPPr2W62nN v+BI8WKCEOUMRlfyM9rQyGPtxh+UBZZKGpHR9+vPj1KuDQjZPqigUenBh3TVyfd0 qy5T+7t6+5fi+B8mj7PSoOA3Wyg7MeUOVy1auK15rF4gZhqluaa1OcH1mEP/7vmn p/3uyiQ9gBbEF4+KwWChDK5bQ0eRS9WaF1/51IfBwoy35+IPMBk3hqzg3EID5pSo na79DyRRlM6SCNH8UPADQHuIWe0O3azSd4I03AaVAtiQ+S3qN9UaYNBnINfYQgtF r4Jo3t1mJDeQKZQZRhkluIDXy9SGKGpEcCYjYqmfhm+/upBw0lZ3hXjv6iWpF85Q cowAOqrj22M0n/gGcQHigiDU/m+9sTCCBtEwggW5oAMCAQICEQDF7uYcSFrF3qgF FtjbsnOSMA0GCSqGSIb3DQEBCwUAMIGQMQswCQYDVQQGEwJHQjEbMBkGA1UECBMS R3JlYXRlciBNYW5jaGVzdGVyMRAwDgYDVQQHEwdTYWxmb3JkMRowGAYDVQQKExFD T01PRE8gQ0EgTGltaXRlZDE2MDQGA1UEAxMtQ09NT0RPIFJTQSBEb21haW4gVmFs aWRhdGlvbiBTZWN1cmUgU2VydmVyIENBMB4XDTE4MDQxNzAwMDAwMFoXDTIwMDUx NjIzNTk1OVowWjEhMB8GA1UECxMYRG9tYWluIENvbnRyb2wgVmFsaWRhdGVkMR0w GwYDVQQLExRQb3NpdGl2ZVNTTCBXaWxkY2FyZDEWMBQGA1UEAwwNKi5kYW1lY29u LmNvbTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAMnCLs0+2HDXTSRh J3b8V62wDpVnzCtlRLguWVUeQs+zMQAI9Bd3kkMb0cGLZTbuGlhtrbYmfHfs5l9Y SkJFWmKMSeAi4uSKqML143qittaICEWV/VnUXemOR9jHqg9wJy7C3lqjIWvkY5sF cCLaeG0eo0QbUSJ0XjkZ4sdVsYhkvcfCfr2C3U0ggPc4yljo+iMwArS10/4sBJPz DOLib0Bgyfdonvei+9txb5ikfyuENWS1QqwqQ5F7n5IwWMCytrVHnw1GwFDk0W76 PqyhZb6Mm1IuxJb9hlqz51X2TKCCW87BbAOth4Q7qI4TOAKxEdjv6De58b2YoFSP lBiHp6kCAwEAAaOCA1kwggNVMB8GA1UdIwQYMBaAFJCvajqUWgvYkOoSVnPfQ7Q6 KNrnMB0GA1UdDgQWBBTt92R40iFvVNFDOXQU4j3CKfLpkzAOBgNVHQ8BAf8EBAMC BaAwDAYDVR0TAQH/BAIwADAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIw TwYDVR0gBEgwRjA6BgsrBgEEAbIxAQICBzArMCkGCCsGAQUFBwIBFh1odHRwczov L3NlY3VyZS5jb21vZG8uY29tL0NQUzAIBgZngQwBAgEwVAYDVR0fBE0wSzBJoEeg RYZDaHR0cDovL2NybC5jb21vZG9jYS5jb20vQ09NT0RPUlNBRG9tYWluVmFsaWRh dGlvblNlY3VyZVNlcnZlckNBLmNybDCBhQYIKwYBBQUHAQEEeTB3ME8GCCsGAQUF BzAChkNodHRwOi8vY3J0LmNvbW9kb2NhLmNvbS9DT01PRE9SU0FEb21haW5WYWxp ZGF0aW9uU2VjdXJlU2VydmVyQ0EuY3J0MCQGCCsGAQUFBzABhhhodHRwOi8vb2Nz cC5jb21vZG9jYS5jb20wJQYDVR0RBB4wHIINKi5kYW1lY29uLmNvbYILZGFtZWNv bi5jb20wggF+BgorBgEEAdZ5AgQCBIIBbgSCAWoBaAB1AO5Lvbd1zmC64UJpH6vh nmajD35fsHLYgwDEe4l6qP3LAAABYtNb8rkAAAQDAEYwRAIgSZDVWx+JZQ2wSSh0 Xv1uPUq9HFK9qXlcSzHNtNMUYR4CIFDN2YKfDYK6QW/awT3//odL42HAEC9H0Tpk j8koX3JpAHYAXqdz+d9WwOe1Nkh90EngMnqRmgyEoRIShBh1loFxRVgAAAFi01vy iQAABAMARzBFAiEAoj/XzI/d+hhbb3FxIIuYxIfwh4KTXXSOWOrX+1c9bTsCIAkI 5iApYorZeB9wZT5M4aONBmdW419WewvglkcYQ0nfAHcAb1N2rDHwMRnYmQCkURX/ dxUcEdkCwQApBo2yCJo32RMAAAFi01vzZgAABAMASDBGAiEAuqr5bwYY41HhjDqJ tWn+uv5aZaAQ6sSYyE8eKtxj7j8CIQDVvTvag63ptHaJfXNa61v2V3SXilDBInK7 KO7+JpVazDANBgkqhkiG9w0BAQsFAAOCAQEAY0nDqM11fqYSEvF3r78GjrvOlPVF xnXGE5eyxGtlZPAYeTqyZe5laLDHNtp7xvF4Ue9DIXhp704et3cttwah9T5lROVA 3Xo5iTyFMGEAHUNkogCg2HbnBrkN2IsRtziFUd77HceHaXfnYdj30XzMt88JX7cj b3vObnII64S0eNVV5+BOqK7TeWm0pGj3fgP9wI7CCld0I2GHJPamUg1roLtlg0QY d6dpFVLNdojknacykwMOYgzi/5a8iXeB1rWyygjCaHGFgU5OmWqurgVPJDEjn5f6 vmID+0bsppAz9OaQ/N0I2KI5mYhtpkxTPdnHpvD3Gv67qCyMBcdaEnDbojGCAdIw ggHOAgEBMIGmMIGQMQswCQYDVQQGEwJHQjEbMBkGA1UECBMSR3JlYXRlciBNYW5j aGVzdGVyMRAwDgYDVQQHEwdTYWxmb3JkMRowGAYDVQQKExFDT01PRE8gQ0EgTGlt aXRlZDE2MDQGA1UEAxMtQ09NT0RPIFJTQSBEb21haW4gVmFsaWRhdGlvbiBTZWN1 cmUgU2VydmVyIENBAhEAxe7mHEhaxd6oBRbY27JzkjANBglghkgBZQMEAgEFADAN BgkqhkiG9w0BAQEFAASCAQAUw3aUadfqgEisWWQdUeglTikfQKZt3rJVpj4j6WdH ZhVA92Am6Yrm9MYj1f2oXBQJ2cWGV62k+o1ZC4djdzTub+BphnGLsbsRwm2gxKTK h58tG6cjiQ/xNGGwi1PxQn7I2vSF6f90N0y62oQOdluSpMkl+A0JR637C5+p2pxA 9tqEd7EIT4Qpb63WR20tb5JzujSahwGE339e7Fz6n/vaolX3ozVHujI28kEiOdxn FQjn8w7d+N7fRmTR58NCSq2AtUNtT1u/E9lb09YZUHj0tLqK37ZCdC2FCgjJXFgR DoyTciGuNZWWspkt/tXZGtqSmMGwGroei7cUv9SDnGWq
Our Engineering Department just informed me that they have a ticket opened on that matter to see what can be done to solve this.
In the meantime, we would recommend using the "RDP File Link" in order for you to be able to stock this information in RDM and connect through the gateway.
James Lafleur
I am also experiencing this problem. Any updates regarding the fix?
Thanks.
At this time, there is no update on this situation yet. I have added a note in the ticket assigned to our Engineering Department to mention that you were also experiencing this issue.
James Lafleur
Add me to the list - essentially, this is the only way of connecting through an Azure RDS gateway to a WVD.
I'm using RDM on a Mac, but the Microsoft RDP client works exactly the same way. First time, it pops up a browser window asking you to authenticate. I would imagine it's one of these parameters from the signscope parameter:
signscope:s:Full Address,Alternate Full Address,EnableCredSspSupport,GatewayHostname,GatewayUsageMethod,GatewayProfileUsageMethod,GatewayCredentialsSource,PromptCredentialOnce,RemoteApplicationProgram,RemoteApplicationMode,RemoteDesktopName,Authentication Level,AudioMode,RedirectPrinters,RedirectCOMPorts,RedirectSmartCards,RedirectClipboard,DevicesToRedirect,DrivesToRedirect,LoadBalanceInfoHere's a screen shot of my RDP file with addresses blurred for privacy:
Thank you for your feedback, I will add this information to the ticket and inform you once we will have an update to provide.
James Lafleur
Any updates?
As I can see, the ticket is still opened at our engineering department.
Let me verify with them the status and get back here.
Is there an update
We initially started working on this and were facing some issues because we didn't have the proper setup to test everything.
We'll increase the priority in order to get it resolved as soon as possible.
Jonathan Del Signore
