Implemented
Color i Navigation panel
We have at hard time seeing the marked entry in the Navigation Panel when there is a jump enabled. It could be nice that the coler could be different ;-)
Best Regards
Kim S.
Very good point, I've created an internal ticket to get this fixed.
Stéfane Lavergne
We've added the fix for Black theme, however I'd like to confirm something with you if possible. Looking at the screenshot provided, the issue seems to be on the "Grey" theme, which is no longer supported, can you confirm if that is the case? The currently existing Light theme has no issue and your query helped us find a similar issue for the Black theme (which is now fixed). The specified fix should be available as early as next version.
Jafran Majeau
Yes it is from the "Grey" theme. Here is the "Black":
That is not better ;-)
The Light theme is fine 👍
Looking forward to get the update.
