when opening a RD session with RDM on a system, which has already been opened with a RD with RDM, the control line on the top shows the system itself and not the "second" one.
This problems seems to exist only in fullscreen mode - when changing to window mode it works fine.
best regards
Roman
I'm not sure I understand, can you post a printscreen please?
Thank you
Devolutions inc.
Hello again,
will try to explain more detailed ;)
i'm connecting to a windows host via RD-session (vietssap1) - control menu on the top looks like image one.
on this host is also RDM installed and i'm connecting to another windows host via RD-session (sapz15).
I this case, the control menu of sapz15 is behind the one of vietssap1 and so sapz15 cannot be controlled (for example minimized).
This problem seem to exist only in fullscreen mode - when change to windowed mode it looks link image two, and sapz15 can be controlled.
Hope i was able to make it understandable.
best regards
Roman
edited by hugofant on 12/1/2009
Hello again,
was my explanation ok for understanding the problem?
problem still exists in 5.7 beta.
as workaround its possible to remove "connection bar pinned" in display settings of first host.
best regards
Roman
Yes it was clear enough but I did not find a solution for now but the open is open and on my todo list. I can't give you a timeframe.
Devolutions inc.
