Using CyberArk integration but RDM seems to be sending the same account regardless of which account was selected.
We have implemented the CyberArk with 'always prompt with list' enabled.
RDM seems to be sending an account that is different from the selected account.
We can't seem to locate much logging related to the CyberArk process in RDM.
What logging is available in RDM related to the CyberArk Rest API?
If you:
show the profiler
switch to the DEBUG tab
set the level to 1
You should see the details of the interactions with CyberArk.
We recommend you set the level to 0 after the test, this has an impact on performance.
Best Regards,
Maurice
Hi Maurice,
Here is the trace.
Double click triggered
Double click node:EASTLAKE (JumpServer)
Size is different... Current: {Width=1422, Height=835} Expected: {Width=1422, Height=809}
Opening in Console / Admin mode
Doesn't seem to show the Cyberark workflow. there are screens I click on before it lists "Size is different". I did select to sent you the trace file. Not sure if that shows more.
Just a note for the rest of the community that the request has been transferred to our ticketing system
Maurice
David,
Did you put the ticket under Shawn's name and account? I don't see anything in my account?
Rick
The ticket is under Shawn, but I just added you as a participant rduvall.
