"Referenced by" behavior differs for credentials and asset contacts
Implemented
If credential entries are referenced by normal session entries or sub connections of an entry, they are either way correctly shown in the "Referenced by" section of the linked entry.
For Contacts, that are linked in the Asset --> Contact --> Reference area, this only works for normal sessions. Contact references defined on sub connection level aren't resolved in the "Referenced by" section of the linked entry.
I'm quite unsure about the behavior in the past, but I think this should have worked with older versions. Tested version is 2021.1.35.0...
Is this expected behavior or a bug?
Best regards
All Comments (5)
I think this is definitively not the expected behavior. I will create a ticket for that.
Thank you for the bug report.
I believe it's a bug. I've opened a ticket so we can fix this. Thanks for reporting this issue!
Hi Devolutions Team, the issue seems to be successfully resolved in 2021.1.40.0.
Thank you for your support and keep up the good work!
Best regards
PS: Where is the "mark as resolved" button in the forums? 😉
There's no button to mark it as resolved, but with your message, we now know that everything is fine :)
Thank your for your feedback,
