I have connections which work fine, if i edit them(or duplicate) they break and won't resave. namely because I have vpn/ssh/gateway SSH forwarding tunnels, it clears the destination field when you open it for editing. It also changes the vpn host field to whatever was originally set in the general -> hosts field (also the port number)
Oddly if i fix up the things and then you edit the general -> hosts field and then save it, that field reverts back to whatever it says in the vpn ssh hosts field (i'd usually have an external ip in the vpn hosts field(first screenshot) and localhost in the general hosts field(second screenshot) to use that ssh local forward tunnel).
Any thoughts on this?
forgot to mention started noticing it on version 2021.1.32(could have been doing it before that but we didn't notice) updated to 2021.1.25 and it still has the issue
Hello Craig,
I just wanted to let you know that a ticket has been opened with our Engineering Department to correct this issue.
In the meantime, as a workaround, we recommend that you create a separate SSH Tunnel entry and that you use it under the VPN/SSH/Gateway section of your SSH Shell entry like so:
Let me know if that helps!
James Lafleur
