Powerline Fonts not Recognised
When selecting a power line patched font https://github.com/powerline/fonts as the ssh terminal font, they are reject as not "monospaced"
"This font is not monospaced, the default font will be applied"
These fonts are clearly monospaced as they are explicitly defined for terminal use.
Which version of RDM and what type of Data Source you are currently using? Also, would it be possible for you to provide us a screenshot of this error message?
James Lafleur
Here's the screenshot. I'm using the Free version on a Mac with the local datasource.
Hi Gavin,
I've download the font from the github link you've provided and I did not find the font you're using (it does not appear in the read me either). The closest would be Hack, and RDM Free does not seem to have any problem identifying it as monospace on my side.
Honestly though, I'm having issue using it anyway, the cursor seems offset (and to get increasingly offset as more line gets added to the terminal). So I don't know how well our terminal reacts to third party font.
Xavier Fortin
