New Entry and Using Templates
Resolved
Hi.
There are a way to force RDM show template list before showing all entries types a user can create?
I would like when users click on "New Entry", it sees first the template list, before choose a blank.
If no, there are a way to block the "New Entry" and let just the "add from template" option?
Indeed, that is something that can be done.
You can do so by going under "Administration" -> "System Settings" -> "Vault" the option you're looking for would be the "Add entry mode".
Samuel Dery
Hi Samuel. Thanks your answer.
But I enabled this setting. My problem is that whenever user uses "New Entry", RDM shows the entry List before show me template list.
I would like user see first the templte list. If it choose "blank", then RDM can show other entries. Is is possible?
We never have seen this way but it's interesting. I will add this to our todo list.
